Windows 8 who's buying/upgrading
Do the pre installed apps just update themselves or do you have to go into something to trigger that to happen?
On the store live tile you'll see a number. That's telling you how many apps need updating. Just go into store and top right corner It'll have a link to updates.
Download 73%, 1hr 15mins to go :(
Downloading at 120kB/s. Good old internet.
Upgrading for now as I'm so happy with my current installation - I have all the functionality I need, nothing is broken and everything is still nice and fast. Will do a clean install some time in the next few months I guess. When I can be bothered.
Although there is an option in Store to Auto Update apps which by default is on...
Must admit that was much easier than I thought it would be :), every thing running fine including Steam and Origin ...very happy :)
Cheers,
Won't it be a hassle that every time you wanna reinstall windows 8 you'll have to install windows 7 first and then upgrade it to win 8 ?
No, as how many times will you need to reinstall, don't forget windows 8 has reset and refresh features.
And for 1hr to install win7 on the odd occasion, is worth the price difference.
Reset your PC – Remove all personal data, apps, and settings from the PC, and reinstall Windows.
Refresh your PC – Keep all personal data, Metro style apps, and important settings from the PC, and reinstall Windows.
