- 12 Sep 2005
- Norwich, England
Well I've been doing it for years so i'll take my chances but thanks
Theres some physics mods that increase bumps and movement for the truck.
To those who have set up a company,what have you called it?
Mines called EuroFreight.Based in Manschestuh.
Is there anyway to go faster than 55? I just bought the most expensive Scannia seven hundred and something horse power, it goes really quickly but seems to be limited to 55mph, even without a trailer which sucks balls. I was hoping to go razing it at 80mph down the motorways.
Yes. The speed limiter and realistic physics mods remove the limit.
Time to murder some helpless pedestrians
Also if I bought this from the rainforest could i use the cd code in my already downloaded game?
A problem i have with the job screen is i always forget to have a look at when my next rest time is so i have to exit the job screen and have a look and then go back into the job screen,so i can get my on time bonus.Aggravates me
Cycling through radio stations while in game would be cool also.
You can with demo to digital download so i think yes.
Yes in the demo it gives you an option to activate/buy the full game so your key should work.
