There not in stock in the UK yet anywhere so no 1 has of yet.
Not true the 8320 is in stock at 1 online store which i cant mention
Must be the one that shipped mine today. Now I've just got to wait for the rest of my build to arrive too.Not true the 8320 is in stock at 1 online store which i cant mention
Also think OCUK had stock at one point?
I'm going from an E2200 booting off a 74Gb Raptor and 4 gb 1066MHz DDR2 to an FX 8320 with a Samsung 830 SSD bootdrive and 8 gigs of 2133 Mhz DDR3. I may find myself too shocked to provide a proper evaluation for days. Still need to order a case and cooling though. To go air or water...and which midsize tower for each?
Hi there
The 8320's are now in stock, other chips due in approx a week, AMD had a delaying shipping apparantly.
Did see something interesting when reading the 8320/8350 owners thread on overclockers.net. Apparently if you turn off cores 1, 3, 5, & 7 iso that you only have one core per module it'll boost IPC circa 20%. Very interesting for when you're running those lower threaded games and the like. This'll also mean you can clock it a little bit higher at the same time so will make it much more competitive in WoW and the like.
just swapped my 8350 order for a 8320.
will have togive this a go.
Do you have links?
There seems to be plenty of 8320 stock knocking around but no 8350, I am guessing they're struggling with yields again.
Wasn't the scheduler patches eventually only included in Windows 8 supposed to achieve that? if you only run a 4 thread game it should only use one core per module anyway?
Well I'll be installing Windows 8 so I shall find out. Which bench would people recommend for me to test it with?Yeah, I thought Windows 8 did that by default...
