Are these worth getting? Looking to maybe relive a bit of childhood from the ps1![]()
Thinking of getting Tomb Raider: Anniversary its a remake of the PS1 game
Bordelands 2 around 10£
http://moonqq.pl/borderlands-2-ru-multilanguage-steam-key-region-free.html
polish website
current exchange rate that give you something around 10£
steam key,if you got problem with activation let me now
need to use polish address
Will i still need to set up a VPN to play this?
GMG - 35% off FM13 voucher code - GMGFM-35OFF-SCORE - Valid until 1200 UTC 9th November 2012. Only redeemable against the digital version of FM13
Theme Hospital @GOG.com £1.49
yes by the looks of it its russian
Interested in that polish borderlands 2.
If its a region free key why would you need a VPN to play it? Ay one bout and tried it?
You need to use RU vpn proxy,after activation you can play and log in from anywhere you want
you can download two versions,one is russian( you can skip that one,second one is english)
yes I did,it works just fine,played the game for 20 hours,tried co-op as well
Instruction how to use vpn proxy:
1.Log in to your steam accounnt
2.Download USAIPDEMO and start it up.
download from here(http://moonqq.pl/VPN?___store=moonqq_polish)
3.Choose Ukraine PPTP from the list and click Connect
(login: demo Passworrd: demo) and click to Connect
4.Activate your steam key
*you got 7 minutes before they disconnect you
I've purchase four games from the website.Not a problem so far
Thanks mate!
Will try it. I did same with battlefield. Although I didn't need a proxy. It's a right hassle when you have to redownload and its Russian though.
This come with language packs?
garry's mod is on daily deal via steam![]()
