Any kind of general purpose grease will be fine, it's not a very critical or demanding application.
Dead battery or charging problem imo
Obviously didnt start and when it did its not holding enough power to hit all the sparks. If you can get a loan of a battery and see if it helps
That was my first thought however it's been a bit spluttery starting in the morning the last few months (ie it initially starts on 3 cylinders) but as soon as it gets going it has been fine. The plugs are due a change anyhow, was last done a good 12k miles ago and I don't want to buy a battery if I don't need one. I'm leaving the battery on charge overnight and will stick it in and see if it goes in the morning. My other thought was the carbs could do with a clean out as it's been about 12k miles since I cleaned/balanced them but that's last on the to do list![]()
What did I do to my bike today? I pushed it home!
Stopped off somewhere to sort my gear out then was unable to get any power despite charging the battery fully just a few days ago. Something in a little yellow box under the seat was whirring away like crazy. Not sure what it was, it was next to the flasher. Possibly related to my installation of heated grips a few days ago?
Clicking type noise when trying the ignition? Sounds a dead battery. Did you remember to turn the grips off? Lol. Done that and had the exact same thing.
Next time stick the bike in 2nd gear, give it a push and let the clutch out and should fire up
Well fair enough sounds like it needs a bit of loving. Just seen many bikes at the track come back in coughing and spluttering and not starting and the battery is the problem. Drawing the spark is the biggest energy sucker from the battery when going so if its going itll be felt.
Also that first frost will start to kill any dying out batterys, esp since theyve little protection from the temperature.
Aye I appreciate the feedback. I really was set on the battery until someone drilled spark plug into my head, it died out extremely quickly trying to start it in Sainsburys car park and the more I think about it the more I lean to battery. Might pop into town tomorrow and see if I can pick one up, a new battery was on my Christmas service list![]()
Worth taking my battery out of bike and keeping it in the house nice and warm? lol
What was odd about yesterday was that it started okay in the morning, started fine leaving work and then all of a sudden it wouldn't go. Seems like somethings "gone" or blocked
Does the tube connect to the tank? Looks like an overflow type jobbie
