Do you have to turn tesalation on in the control panel with amd drivers?
That was with dual 1150/1700 clocks.
No. Can see it's the same IQ as nVidia default here.
The knackered one is already out and the monitors are down and ready to be boxed up. I couldn't bear to have them all plugged in and idleing around 50c.
I am thinking of selling the 680 and getting a 7970 just out of new toy syndrome. Do you think I would see much difference at 1080p?
Rusty I got a question regarding the smoothness between the Nvidia and AMD cards.
If you don't mind risking being "burn like a witch" by fanboys, can you give me some personal opinion in terms of the percepted smoothness between the Nvidia and AMD cards at around 30-45fps?
So you're down to 1 monitor and 1 card now? I run 2 monitors and when @ 3840x1080 with the taskbar stretched across both screens i get same idle temps as if i was running just 1 monitor ( around 30c - 32c) and clocks are 300/150. Just wondering why you went down to 1 monitor instead of 2.
And thanks for doing these benchmark tests.. its been a very interesting read![]()
Personally I enjoy 3 screen gaming a lot.
one screen 2560x1440 would be a good replacement for many.
however I use 120hz screens and as far for my use, its just isnt possible for me to play at 60hz anymore, eyes get strained.
3monitors I idle at 500mhz.
for me its silent.
Nice work Rusty, I can totally appreciate how much time these things take and would like to thank you for the effort.
Now you are down to 1 7950 how about a comparison with a single 680 ?
I think it would be even more interesting to many people around here![]()
No you are missing my point, there are situation which the frame rate would dip to 30-45fps which may or may not due to graphic card limitation. I'm not talking about getting that kind of frame rate at all time in games...I'm talking about it would usually be at 60fps, but would occassionally dip to those range.notice difference, no.
8% or whatever it might be is like 6fps or such
difference happens at higher resolutions
if you have 30-40 fps in the game you play, you either increase it buying a extra card for cross/trifire/trisli or lessen the visuals.
with extra monitors you get some inputlag also, even if not much low fps isnt enjoyable on any machine.
I run a single card and have lessen visuals until my fps works for me at 5040x1050, fps games I lessen visuals a lot, and in a rts game or MMO I can run maxed most of times. 1200mhz OC on the card helps and 4.8ghz cpu.
i get better fps on 2x7970's but the 680's run super smooth even with less fps.. i could never get the 7970's to run like the 680's unless i dropped some settings.. Im a AMD fan boy at heart :s
I was merely asking for Rusty's feedback, as I myself, and others have felt that Nvidia cards give a smoother experience, despite having same/lower frame rate sometimes.
I can't quote every post that people that mention that, but here's one from this topic for example:
(XFX Double D's)They were £218 each
Marine,
The stock 7950 alone has jumped up in price by £28 to £250!
I was accused of trolling for suggesting the same thing.
A 7950 at clocks of 1200 core and above will be keeping pace with a gtx680oc pretty nicely as in the ocuk benchmark thread they are very close to 7970's with the same kind of clock speeds. A 7950 imo is the only card to buy atm if you have no preference for nvidia and want a high end card. There is only 5 percent difference or smaller clock for clock when comparing to a 7970.
They have been creeping up the prices, but they are still no more expensive than most other retailers.
And i don't think you can beat the service here, i think that is worth a few extra % even.
Still, 7950's will have been selling very well since the price drop and thanks to our help in recommending them over and over again.
If they have been profiteering off all that; well, they are a business in business to make money, to pay people wages ect... can't really blame them for that.
If they were the sort of retailer who snub you once they have your money, as a lot of them do, i might take a different view, but they don't, there rather good when it comes to customer service.
