Nice, I keep seeing that but I'm nervous of going through eBay. I'd rather spend £480 and go to O2, so I can at least kick off with them in a highstreet store if I need to.
Nice!
Which headphones are people using? Are the android ones such as Klipsch S4A (with inline controls) compatible with the note 2?
Yes I ordered it from their website. No Orange branding whatsover i.e. no Orange symbol, or Orange Apps etc.
Using my Sennheiser MM70i 's . Got them nearly 2 years ago and they're still sweet, shame only the play/pause button works and not the volume up or down / fwd or back with the note 2. Also own a pair of Audio Technica M50's which sound great.
official charger is a 2A jobbie - its more powerful than most USB chargers which are normally 1A.
So 2A to charge a 3100mah(3.1A) would take jsut over an hour and a half to fully charge.
I was wondering, how do I add another home screen on my note 2-touchwiz. Max is 7?
How can I use some sort of tablet mode on the homescreen - some form of landscape mode? Any way at all?
Does power saving mode have that much difference on battery life?
Lastly has anybody found that when the samsung note 2 wall charger is plugged in - it makes a whining whirring noise, really really annoying...... or is mine just defective?
The battery is 3100mA.hr, operating at 3.7V; this is 11.47W.hr.
So, with a 10W charge, you're looking at a theoretical charge time (from zero to 100%) of 1.147hrs; roughly 69mins.
Actual charge times should be fairly close to this with a high quality charger, so expect to charge for about an hour from a near-flat (~10%) battery.
Yeah but you charge at the rated voltage so your going off battery capacity. So 3100mah from flat at 3.1A is 1C charge rate, so 1 hour. But even though the battery should still have 20% in it (the phone says 0% but that's so the battery doesn't fully discharge) so you're only needing to put 80% of 3100 in, so it should take less than an hour at 1C, but it's not at 1C it's nearer 2/3C.In theory, it should be a little over an hour:
In practice though, it's closer to two hours for a full charge. Some of that will be down to inefficiencies in the electrical conversion process (loss of energy as heat while charging etc), but it shouldn't make that big of a difference (20-30% maybe). I suspect that the actual current delivered is more like 1.4 to 1.5A (7 to 7.5W).
