I burnt a trace when chipping my Xbox, use a conductive pen to rejoin the broken trace. looking at your pic it looks like you broken two traces
If I knew what I was doing I'd give that a go. Thanks.
If you're running without the bracket is is just the pressure of the cooler holding the CPU in place?
Look below lapped pics mateTemps???![]()
^now thats nice rapt0r, i'm using a tad more V and only 4.7, what board are you using?
do you have core temp?? if so whats your V.I.D
VID is 1.2 @ 5ghz using offset, stock VID is 0.936
board is Asus p8Z77-V Deluxe
yes i have coretemp, not installed though
