Yes, it is all pretty pointless, including that which you ask them to post. A better idea is by comparing it to something else you've used in a similar manner and commenting on whether it lasted a bit better or a bit worse, much like the guy did comparing it to his similar use on his iPhone 5.
As has been said, even just the area you're in, the network you're on and the radio ROM your using are much bigger factors than how many text's you sent. With battery, you just can't be that accurate/specific.
Seriously, surely you've notices how two people how would appear to have very similar usage have wildly different results?
Surely can you not see what I mean, especially considering that you review phones for a living
Of course no battery life is going to be the exact same if usage is roughly the same for the reasons you said, signal strength etc. however, it is very close if those factors are roughly the same i.e. most of the one S owners here can get 4-5 hours on screen time throughout 1-2 days easily with similar usage just like some GS 3 users and their battery life in the thread here.
BTW if these sites posted the relevant screenshot (the history showing wifi, awake time etc.) then we would know what the signal strength was roughly like.
How is what that guy posted of any use at all, so what if he compared it to the iphone 5? Both completely different phones that have different OS.... and again, was his usage roughly the same on the iphone 5? Did he actually charge both phones fully? (many review sites don't
) Also he doesn't seem to have a clue how android works with regards to apps/multi-tasking and RAM, which makes his opinion even more worthless.
I just can't see how you don't see what I am getting at and how you can think being a bit more specific is pointless when compared to their crap efforts
As I said before, for all I know that usage could be similar to mine on the S in which case it is **** poor or he could have loads of syncing etc. going on in which case it is great, if he had posted the info. which I and others would like to see (which doesn't take like an extra hour to do, at most 5-10 minutes more) then I would have a better idea as to how it stacks up compared to phones like the one S, X, GS 3 etc.
EDIT:
And yup, apart from camera, storage and possibly audio (loudspeaker) as well as possibly battery life (need to wait for gsmarena's test for audio and user opinions on battery life and for the software update), the N4 is better than the GS 3 in the other areas, the GPU/CPU just blows exynos/mali out of the water.
