Man of Honour
- 8 Nov 2007
- Outer Space
Hi guys,
Can I get a quick disconnect for 7/16 ID tubing? It seems that Koolance don't do this size, unless I'm missing something?
I'm thinking of adding one inline so that I can disconnect the tubing and then remove the Koolance fitting thus acting as a drain port, as it's at the lowest point in my loop (bar the rad which is underneath it)?
Would this work or should I get something else, if so what?
Thanks
Thanks
