Only as much as a 10% longer hose need a bigger pump.It's simple bigger radiator needs a bigger pump to maintain pressure and overcome losses. If the Kraken has a bigger radiator and more powerfull pump with decent fans it will be better.
I doubt there will be much between them my half knackered H100i can keep my i5 clocked to 4.8ghz under 70.c so it has an easy lead to follow.
Yes there is friction in the system and it is part of the equation but I don't think it is much of a factor here.
