Voltage/temps for 3570k @ 4.5
22 May 2010
Minibotpc
A word of warning, the path from 4.5 to 5ghz isn't as straight and narrow as it sounds. From what I can tell most chips will do 4.5 (at whatever voltage) but once you start getting to the 4.7-4.8 range there are typically massively diminishing returns and your voltage surplus will go out the window very quickly.
For mine i needed 1.4v for 4.7ghz and after that it isn't even feasable to try and achieve 4.8ghz.
Times are nice though even at those voltages. After a few hours gaming my temps just touch shy of 78c
15 Jul 2012
Mine needs those kind of volts for 4.7 too, but 78c would be too hot for me. I use 4.5Ghz and temps never above 55c gaming, delidded with D-14. Maybe under water soon.
22 May 2010
Minibotpc
I'm okay with 78c or even 80c would be fine for me, i can't see it causing any long term damage at all. It was scary though doing IBT on very high and the temps touching 105c haha! I closed it down as soon as it got past 100c and thought to myself christ that was hot!
De-lidding hard? I really don't wanna void the warranty on my chip.. so i don't suppose theres a way of resealing the chip afterwards?
Permabanned
29 Feb 2004
fife, Scotland
Thanks for the advice, I may try it, but I probably wouldn't leave it there anyway. 4.5 is plenty for now. Just for the satisfaction of knowing I have hit 5Ghz more than anything!
15 May 2012
Louth, lincs
Yes you can reseal, see the de-lidding thread, some products there which will do the job, but if your worried about voiding the warranty, maybe rethink about doing it.
http://forums.overclockers.co.uk/showthread.php?t=18451271
15 Jul 2012
Delidding isn't hard it's more risky. You need a non flexible blade like a stanley knife that won't cut into the pcb of the cpu when first cutting under the IHS. After that I used a TIM spreader and it came off easily. It took me 2 attempts to get it right, first time I killed my 3570K.
You can reseal it with silicone exhaust sealant I think. I have some but tbh the mounting bracket holds the IHS on so well and it makes it easy for me to reapply TIM to the CPU die itself.
I put voltage to 1.55V, and can't boot at 5GHz. :p
