*** The Official Google Nexus 7 Thread ***
My connection speed is awful , and my laptop is superb but the nexus 7 is terribly slow , it gets 1Mbs link speed , even though the signal strength is "good" , my laptop gets 300Mbs in the same place! not happy!
is there anyway to improve the speed? it only increases to 11Mbs right next to my router!
(link speed - not download speed)
something is not right...
The nexus 7 can do 802.11n so either 65mbp or 150mbp. i also recently used it on 5ghz 802.11n so it has an up to date network interface.
have you tried resetting the nexus 7 to stock and then try the internet again? also what are you using to test the speed?
yeah but where on the nexus 7? as i cant say i've ever seen connection speed mentioned? have you installed any apps or software yet?
I just started following the nexus 7 when popping into HMV to kill time. Quick question.
Why don't you buy the non 3g version, OTG and a dongle. Would it not work out cheaper. Sure it might look ugly.
Many people are reporting that the 4.2.1 update has made the Nexus 7 less laggy than when 4.2 hit. But yes, main reason was for the December bug. Not that I noticed it was missing from mine.
