Permabanned
- 19 Jul 2012
- Buckinghamshire
HIS, Sapphire and Gigabyte would be my next choices.
Nice
I would go with Gigabyte.
Well I got my refund email nownow which card to buy?
I think i will go with http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HS&groupid=701&catid=56&subcat=1673
What would be the difference in performance between 7870 and 7950
Please let us know if the replacement is better. Do you know if my card that was sent out on Tuesday would be the "new" batch?
[WU-TANG]GZA;23273775 said:The TFIII that I sent back was part of the 'new batch' and it was still not performing as it should. Just about to receive my replacement (HIS IceQ Boost).
Obviously not all of the TFIIIs are faulty so fingers crossed you get a goodun...
Rang up today, was told they're just swapping them straight out for new batch cards. Don't know why they didn't just say that the first time I raised the issue, but that's a result either way.
Gigabyte 239 pounds, should I buy it?
That depends on a few factors:
1. What is your current spec?
2. What games do you play/intend on playing?
3. Do you plan on further upgrades in a short time?
4. Could you wait for the next gen of cards?
5. What is your budget?
1. In my signature
2. Depends what intrests me
3. Not really
4. How long?
5. 250 is the max.
I had the msi twin frozr III 7950 but it was faulty so send it back and now need to buy another card since now Im using GTS 250 1gb 775/1050
