 - 26 Sep 2012
Hi guys..
So It have been a bit quiet from me lately, but I have had an exam I also had to study for..
First off:
You remeber the all of a sudden leaking from the flowmeter?
Well it seemed to be the o-ring sitting badly, so tried fixing it but no luck.
So it goes out of the system (didn't need it any way) which might just make the whole build look a bit better and less caotic
But the leak did bring me some troubles..
MY pump didn't start after so was a bit mad at the time
But out the pump goes and with a bit of time on the hot radiator fixed it (it had taken some water in)
So I said I would enter the Cooledpc.com competion but in the highst catagori, so I need to take away the two motherboard blocks and reservoir.
So empty the build and now when I had it all out, I just need to change the fan on the PSU.
WHY?
Well, it is a nice PSU, but in idle, it's fan was the most noise part, which I just can't take.
So out with that and in with a noctua P14 - FLX which is really good = no noise but better airflow.
Really love the noctua fans, but can't use them in general because of those damn colors..
But the res, mobo blocks and flow meter came out, and the loop changed a bit and it all turned out really great (I believe
Many great pictures can be seen here:
http://www.cooledpc.com/build/224
Hope you like it and will share and vote
Next in the coming week, I will be shifting back the res and mobo blocks to finally finish the build and show you some temp, bench and OC
First off:
WHY?
).Many great pictures can be seen here:
