People need to back off of Top10 before i get knocked out!!![]()
Im sure someone will find a way! got my block for my 680 at my girlfriends studio ordered it from OC came quick, so tomorrow 680 will be going under waterchilled!
Why I am helping you, I will never know
How would I improve Physics score gregster!! thanks for the link will read!
lol
Sweet. I never liked adding volts whilst it was on air but under water, temps are so good and with your chiller, I will be knocked off the 2nd spotWhy I am helping you, I will never know
Looking at the GPU scores, would it be safe to assume that CF 6870 is on par with a 7870 performance wise?
or doesn't it work that way?
How many volts are you putting though your 7950 core to get it over 1200mhz ?Yeah same, I just upped the clocks a little to put me back into the top 50 overall (even though I won't be able to reclaim my top 7950 GPU only spot) I'll probably run it again today with iGPU disabled in the BIOS. It is annoying that 3DM11 can't easily recognise whether MVP is enabled.
Looks like I've found my limit with not being able to increase the vCore on my card past 1.35v.
Card is a MSI R7970 Lightning BE
Core clock 1347 MHz @ 1.35v
Memory Clock 1995 MHz @ 1.66v
SCORE
P11566 3DMarks
GRAPHICS SCORE
13047
PHYSICS SCORE
8927
COMBINED SCORE
8218
http://www.3dmark.com/3dm11/5124819
http://www.techpowerup.com/gpuz/wh55n/
- pgi947Looks like I've found my limit with not being able to increase the vCore on my card past 1.35v.
SCORE
P11566 3DMarks
GRAPHICS SCORE
13047
PHYSICS SCORE
8927
COMBINED SCORE
8218
Determination to keep us 2600k guys in the top ten has driven me to another suicide run!
www.3dmark.com/3dm11/5126883
12375
12859 (graphics)
[email protected] 1.6v
7970@ 1340/1775 1.32v
