Even if it'll run all DHCP/Firewall/Download needs?Your server needs to be on the LAN side of the router.
I'll probably keep things as they are though until I get a second mini-server...
Even if it'll run all DHCP/Firewall/Download needs?![]()
I'm joking. it was a typo.Almost certainly. Putting a server between your modem and your router makes almost no sense.
I meant to say that I would run everything on the server, DHCP/Firewall/Shares/you name it, 24/7.
and just use the Router more for wifi/usb storage.
this is what i had envisioned but it is probably not possible
It probably would be possible, but it would be better to loose the wireless link between the two routers.
I'd keep router 2, but replace router 1 with a switch or with a wireless access point with a built in switch (a reconfigured router could do this). Then connect between them using Powerline adapters. The best option would partially depend on whether the wireless devices could be connected to router 2 or not.
yes they can that is fine.
ah i didnt think about power line adapters.
seeing as i do not have router 1 yet what would be the best thing to buy for it?
Is anyone running hyper-v on microserver by USB or installing on to hard drive like ESXi does? Would rather it to just boot to USB that's on the motherboard if possible and use the first 250gb drive for VMs and additional drives for data storage.
I'd like to make the Microserver a little quieter. Any tips or recommendations for which fans etc..?
Thanks
New micro server @ 2.2ghz:
http://www.wegotserved.com/2012/12/07/hp-proliant-microserver-n54l-full-specs/
lol @ the comments. The greedy sods expect a budget server to have premium components and features.
Normal service then...
The only things I would have expected are? USB 3 & higher official memory support and maybe better RAID.
