- 29 Dec 2004
- Shepley
That is awful!
are we tackling knife crime by giving everyone stab vests?
Tour de France 2014 starting in Yorkshire and with a stage finish in London!
http://www.bikeradar.com/road/news/article/tour-de-france-2014-to-start-in-yorkshire-35982/
just listened to that, was quite interesting, didn't like people coming in and bringing stuff up AGAIN after it had been discussed (ie helmets are mandatory in auz, we know but a) it doesn't save you from a truck driving over you b) it leads to a drop in use, c)are we tackling knife crime by giving everyone stab vests?)
The Australian thing is overplayed, it recovered after initial drops and now there are far more cyclists than before the helmet law.
The total number of head injuries declined from 702 in 1988-89
to 581 in 1999-2000, with the most marked decline in the ‘0-14
years’ age group (Table 2). However, the majority of the decline
occurred prior to the helmet legislation and before helmet use
compliance increased
New Zealand introduced mandatory helmet legislation on 1
January 1994. There was a dramatic increase in helmet use and a
51% drop in the number of trips by bicycle between 1989-90 and
2003 to 2006 [26]. An analysis of changes in head injury rates
noted a gradual decline over time, but no marked improvement
associated with increased helmet use compliance [27].
During these dark winter months I can't help but feel the biggest safety improvement that should be being promoted is a good set of lights.
My nightly drive home ill see about 5 cyclists and I'm yet to see one with anything more than a pathetic set of LEDs which can barely be seen.
My two cents
My two cents
i think you need to get used to it a bit.. every winter i will feel cold like really cold for a bit and then my body kinda gets used to it and i still cycle in jeans and t-shirt with thin leather jacket..and leather gloves
AS you may recall, i may have said that i feel the cold really badly
well, i wear shorts with leg warmers on but if its REALLY cold out i wear my base layer under that, seems to be ok, but I am thinking of buying some sort of tights for winter use, so i can use these instead of struggling with the leg warners, so any recomendations?
Jeans are pretty thick though compared to typical riders attire especially is they arn't tight jeans, dunno how you do it though as when they get wet they must be awful to wear.
and i don't like baggy trousers so they are slim fit ones
and yes i do have an extra pair in my backpack in case it rains then i can change them at work, otherwise they are alright doesn't really restrict my movement much - but may not be as comfy since they don't have any padding
i guess im just used to it.Soon you will start riding with your right jean leg rolled up, replace your bike with a brake-less fixie, run an inappropriately massive chainring and have flat bars that are only the width of your hands.![]()
single gear = less maintenance, not that i had to do a lot on my triban 3 yet! done ~800miles on it and only cleaned it and lubricated the chain and other moving parts..
