Right. Lets start of with a bit of background... because i can, and ive been away from the forums a while
I got an akasa for my first build a couple of crimbo's ago
Ended up with 8 cores of xeon for a stupidly good price, and ended getting a drip of electrically conductive thermal paste in LGA 771 cpu socket pins. Never snapped a piccy of this build but id still be using it now if i didn't bork the board
So i set of and sold the cpu's and went to an amd setup Got a Phenom II Zosma 970T quad core and an msi board (witch i must mention i was advised not to get). So by April i had a rig working again, i installed windows 7 and the proceeded to the bios. I hastly unlocked it to a 6 core, and shoved it up to 4ghz without any need of a voltage bump... Temps were good as well, or they seemed good for the 10 minutes i prime95'ed it before the board exploded, being a rookie i sent the cpu back to the ebayer to test and it never found its way back to me, though the board was replaced by a asus (found out when i got a cpu how splodgey this board was)
Anyway, My akasa with the best cpu ive ever owned (6 cores 4ghz no extra voltage) in its early days (before getting a good gpu and heatsink)
So im actually very proud of that rig for a first attempt though i do see why i shouldn't have been so ignorant and got a motherboard with better power phases. because then most likely id still be using that zosma chip.
So with no cpu i scrounged for ages and picked up a phenom II x3 during that summer and found my board had a lot of chipset issues (bga solder and overheating, causing lots of issues)
At this point i also gave my akasa to a mate and used a CM stacker (horrible case)
eventually early this year i got the money to drop on over to intell.
I got a sandybridge I5 (2310, as i got it half the price of a 2500k) and got a brand new gigabyte z68xud5 B3 motherboard, And soon after picked up a DCII 7950 (desing fualted so asus have kindly offered to replace it.....after i showed them how many trading standards they were breaching with this single card and threatened to take legal action)
and had a Solar eclipse donated to me by one very kind gent (setter on OCUK forums)
and dropped my system in and gave the stacker to another friend.
and here it is
Anyway, as you notice its sort of a solar eclipse and sort of not... its had half of it replaced with a normal eclipse, and eventually i managed to source a black chassis (ironicaly the one from my first akasa) after we took the motherboard tray and put it in an xps 700 case.
So.. Here i go again, im doing some modding to the akasa and another project log for you guys, and remember, its sure to disappointing and be slow moving...
and here it is
Nice project
Haha, nice fuel xD
new there was sumink i was missing, Rad grill to be purchased after crimbo i guess, should cover the mess a bit!
