Been spending last hour or so setting mine back up so here are my impressions quickly:
- definitely smoother throughout especially in the menus and sense stuff, it does feel more snappy too without a doubt
- haven't noticed any difference in wifi performance or cell reception yet
- only a couple of extra bloat stuff added, however, you can't disable some of the stuff that you could originally like HTC sense stock stuff, notes and task apps but as sarge pointed out can at least disable their location stuff
- new keyboard sucks so back to swiftkey 3
- overall the UI is better for sense stuff apart from the battery section and the power saver notification is annoying
- we can now add widgets from the app drawer using nova/apex without having to root
- not used camera yet so can't judge quality improvements if any
- can't judge battery life cause someone at HTC thought it would be a good idea to remove screen on time...........
You haven't quite got full control of themes for the message app, only preset sense themes so no black background
sense browser is even better now, really like what they have done with the quick controls and I don't see any reason to use quick ics etc. for now.........
Just had a quick go on google now, don't need it and will just drain battery so it is disabled!
