Flashed the perseus kernel on mine. How did you oc the GPU Kreeeee?
Edit: Nevermind, found it: STweaks.
Aye. You may need to undervolt while overclocking (I'm sure you do this anyway) to keep temperatures down to stock levels.
e: Actually sod AOSP theme, this! http://forum.xda-developers.com/showthread.php?t=2029712
That's what I'm using
Edit*
The free version just customises the toggles, donate <£2 and you get an email with the full apk that allows you to change lots of things.
Gonna gradually drop the volts some more over the next few days, been gaming a bit today and it did get a bit warm but no crashes/lockups. Cpu seems happy at 1.8 and Gpu at 800.Battery life still seems good but I'd recommend this kernel because it fixes the exynos mem security hole without breaking the camera!
I'm getting a slight humming noise coming from the charger whenever it's charging my phone. Never had this problem with any other chargers and after a quick Google it appears other people have had this issue and that it's normal?
I've tried it from other sockets in my house and the noise is still there, it's really annoying when you're trying to sleep.![]()
Really loving this phone, but have noticed that the battery drains itself at a rate of 1%-ish per hour when left unattended (e.g. if I take it off charge before bed, I'll wake up and it's at 92%). I've checked in the battery usage and in these cases it appears to be 'Android System' that's pecking away at the charge level. This happens even with GPS/Wifi and Bluetooth all turned off. My old Desire HD had an appalling battery life, but even that would sit happily for long periods of time with GPS/Wifi on, without the battery draining so noticeably.
Anyone got any ideas of why this is, or what I can do to track it down? The phone isn't rooted or otherwise fiddled about with.
http://www.engadget.com/2012/12/28/samsung-galaxy-note-ii-reportedly-coming-in-black/
Black Note 2! Would be immense.
