*** The Official Samsung Galaxy Note II Thread ***
Flashed the perseus kernel on mine. How did you oc the GPU Kreeeee?
Edit: Nevermind, found it: STweaks.
Time to update to Wanam 2.2 (LL4) and then flash the new AOSP JB theme for it :D
e: Actually sod AOSP theme, this! http://forum.xda-developers.com/showthread.php?t=2029712
e2: Amazing :D
Love the Torch option when holding HOME button on the lockscreen :)
Aye. You may need to undervolt while overclocking (I'm sure you do this anyway) to keep temperatures down to stock levels.
Gonna gradually drop the volts some more over the next few days, been gaming a bit today and it did get a bit warm but no crashes/lockups. Cpu seems happy at 1.8 and Gpu at 800. :) Battery life still seems good but I'd recommend this kernel because it fixes the exynos mem security hole without breaking the camera!
That's what I'm using :)
Edit*
The free version just customises the toggles, donate <£2 and you get an email with the full apk that allows you to change lots of things.
1250 cpu and 1050 gpu should be stable voltages on any note ii.
I'm getting a slight humming noise coming from the charger whenever it's charging my phone. Never had this problem with any other chargers and after a quick Google it appears other people have had this issue and that it's normal?
I've tried it from other sockets in my house and the noise is still there, it's really annoying when you're trying to sleep. :mad:
In the end I just plugged the USB cable into an iPhone plug, kind of annoying that a £400+ phone comes with a shoddy power adapter that sounds like there's a really annoying fly buzzing around the room every time you want to charge it... :p
Really loving this phone, but have noticed that the battery drains itself at a rate of 1%-ish per hour when left unattended (e.g. if I take it off charge before bed, I'll wake up and it's at 92%). I've checked in the battery usage and in these cases it appears to be 'Android System' that's pecking away at the charge level. This happens even with GPS/Wifi and Bluetooth all turned off. My old Desire HD had an appalling battery life, but even that would sit happily for long periods of time with GPS/Wifi on, without the battery draining so noticeably.
Anyone got any ideas of why this is, or what I can do to track it down? The phone isn't rooted or otherwise fiddled about with.
If it really does bother you, turn on airplane mode, it disables your mobile network though. Just leave it plugged in? I keep my wifi on and various things are kept syncing. If i do turn off wifi + gps I only loose around 4%, but I do only sleep around 5-6h max most days.
Does anyone know why my music player just seems to stop on this phone? I had it on speaker and was in the middle of working out listening to an album and after about 20/25 mins the music just stopped and i had to go back into the phone and take it off pause? Its quite annoying. Its done it a few times now during workouts.
My Note 2 was delivered yesterday. Stunning, stunning phone. Still getting used to all the touchwiz stuff having come from years of Sense. Took off charge at 06.30 this morning and after a moderate to heavy days use I'm sitting on 28% battery left. My old Desire HD would have been dead by lunchtime.
Just received this in the post, it's amazing, had a little play with it. Now to let it fully charge.
Was anyone else confused by how the plug worked? It did leave me confused for a few moments until i realised that the 3rd pin folds out!
Haha, put lightly, no... I didn't have any issues with the 3rd pin.
Although my plug makes irritating high pitched noises. I just recently samsung about it, lots of others appear to have the same problem.
