I *never* use notification sounds (it's the first thing I disable), but I've got an odd sound issue where my sound goes suddenly quite at the most random of times, such as when plugging in my phone to charge or copy files.
Far from all the time, but it's happened a couple of times in Foobar and PotPlayer. Foobar's fix was equally odd, as all I had to do to get it back to normal was adjust the volume in Foobar (the global volume didn't make a difference).
For the record, I've got a Xonar DX and am using the beta drivers from ASUS.
Could you tell me what this folder would be called? I'm not on my laptop at the moment so cannot view the Windows 8 folder.
Tried win8 install disk on a Pentium 4 machine but gives error during load. Is that hardware or flash bios to get the execute bit thingy. I probably wont do either, its an old lounge micro pc box
Basically, with the processor requirements that Microsoft is imposing with Windows 8 (Physical Address Extension (PAE), NX Bit, and SSE2), that essentially means that the minimum requirements from both vendors are:
AMD : AMD Athlon 64 (Starting from Q4 2003)
Intel: Pentium 4 Prescott (Starting from Q1 2004)
So Athlon T-Bird/XP (no NX, SSE2), Pentium III (no NX, SSE2), and Pentium 4 Willamette/Northwood (no NX) are out, in terms of upgrading to Windows 8. Windows 7 and Linux distros are still an option for systems with these older processors.
Just wondered basically if anyone runs win8 on a P4 cpu. I figured this is a common install problem, my apologies![]()
Some older GFX cards aren't supported either.
So not much point in keeping an older machine any more.
Maybe this is the mobile code showing through but one machine is running w8 on a Rage 2 which is 17! year old hardware. Does video and everything, no hitch
Its used for iTunes, recharging - its not mine, perish the thought. I skipped from Barton to Conroe long ago, P4 always had a bad rep from what I remember
I'll leave it setup on xp and let them know about the power consumption thanks
Since yesterday I'm having trouble with W8 asking me for a password when I restart from sleep. I changed it back in the power options but it's done it twice again today. I've made no hardware changes and run an anti-virus and malware scan but nothing showed. Any ideas?
http://www.pcworld.com/article/2015587/how-to-bypass-the-windows-8-password-screen.html
I remember doing something different. Meh
