- 18 Oct 2002
Hi there
When 911's first came out, N-rating was important, not many cars had such wide rears with all that weight over them.
Now its not so common, some now believe N-rating is just a form of Porsche tax, some still believe they change the spec of the tyre slightly.
Fact is Michelin tested the PSS on Porsche, designed it with Porsche in mind and Porsche themselves fitted it to GT3's and used them at the Experience centre, so they clearly work fine.
On my 911 I've had Pirelli Pzero Rosso (Terrible), Michelin PS2 (very good, average in wet) and now the Michelin SuperSport which is better than the PS2 at everything, dry, wet, wear, road noise, comfort, it is just excellent! Next I am trying Pirelli Corsa System which is a track focused tyre and will then no doubt be back on SuperSports again.
I just had my geo re-checked and slightly adjusted on the 911:-
Running the above, the drive and grip is sublime, no front-end lightness or lack of confidence, just grip and great confidence.![]()
My GT3 settings aren't far off and it drives very nicely and a little more planted than standard settings. I run 2 deg front and rear. No toe front and a little toe in at the rear. ARBs both in the middle.
