Are Lockheed Martin actually putting a lot of work into it? Are they supposed to be releasing a more end user version? I bought the $50 "Academic" license, not spent much time on it though.
Would be nice if there was a real alternative to FS X (64bit, graphics card processing offloading etc) and it's 6 years of growing long in the teeth. X-Plane is pretty decent, but it's nowhere near as end user friendly.
v2 is meant to be a big update. In terms of "end user version" not sure if that's going to be the current Academic version or they building another one. One thing I heard/read is that if you have the Academic one you need to buy V2.
Just looking at some online flight plan it has the following for egkk to eham: CLN L620 REDFA/0034
Where would they go in the FMC? I'm just little confused here.
So I have this route here.
CLN L620 REDFA
So you start with RTE and type in EGKK and then EHAM click next page.
You have Via and To. You add CLN on then right side(To) on the left side it will say Direct(Via). Below that(Via) you type L620, opposite side(To) you type REDFA you then click activate and EXEC.
Once that is done click DEP/ARR, Left side click DEP EGKK and choose CLN2X(that's the SID) they are different depending what rwy is in use. We using rwy26L.
Once you added that, again press Activate and EXEC. Go to your legs page and you should now see some added waypoints which make up your SID e'g KKW04 KKN06 etc.
Click back on DEP/ARR and click EHAM ARR. Let's say rwy18C is in use, choose ILS18C, on the left side is all the STARS for rwy18C, we going to choose REDF1A, that STAR has a Trans which is SUGOL, click that.
Then again click Activate and the EXEC. If you get any route disconnects click the way-point below it and then click the disconnect this will join the route up.
you must always click EXEC after you have corrected the disconnects.
If I have confused you any more. I can go through it with you on mumble I don't mind.
Edit. I forgot on the RTE page you will also have to add rwy number. 26L
Software like Aivlasoft EFB, you plan all your routes first then save that file and when you click the RTE button on then FMC you add the route you saved e.g, EGKKEHAM01.RTE . You dont have to add each Via or To
I then click on my DEP/ARR and add the SIDS and STARS after.
http://www.aivlasoft.com/products/efb/images/routesetup.jpg
