- 9 Aug 2009
- Internet
New update today
GENERAL
GUI
MATCH ENGINE
v1339
- Fixed runtime error when viewing other users match in network game
- Fixed rare FMC crash in February 2015
- Fixed rare edited Dutch competition crash
- Fixed rare instance of save not loading with edited db
- Fixed No Transfer Windows achievement/unlockable completion
GUI
- Fixed sorting of player training focus columns
- Fixed display of competition news screen
- Fixed potential rating of youth candidates displaying incorrectly
MATCH ENGINE
v1339
- Tuned dribbling generally
- Fixed issue that counted too many dubious instances of running past opponent
- Toned down poor decision long shots
- Fixed some instances of short, under hit passes
- Made keepers more aggressive in meeting short back passes
- Slight improvement to defender positioning for short goal kicks
- Fixed bug that could cause players to try to clear ball from in front of own goal instead of scooping it clear
- Improved last ditch tackling and engaging of ball close to own goal
- Slightly reduced defender reactions at lower levels
- Improved engagement of ball player to reduce effectiveness of running with ball
- Fixed some instances where defenders don’t engage ball player around own area until it’s too late
- Further tuned kick and header accuracy
- Reduced aimless passes into channel from high up pitch
- Fixed rare instances of dead ball not being delivered correctly into opposing area
- Further tweaked defending against ball player
- Fine-tuned run past opponent counts slightly further
- Made dribbling slightly harder to achieve at higher speeds
- Made most players a favour more direct passes slightly
- Small fix to player reactions to loose balls
- Made defenders more aggressive in terms of looking to tackle ball player
- Fixed players with low closing down settings doing it so high up the pitch
- Fixed players set to specifically man mark opponent from leaving him too eagerly to engage ball player
- Small fix to specific man marking when opponent goes close to opposition d-line
- Fixed some interceptions being logged as tackles
- Fixed some instances of players playing opposition onside when defending free kicks
- Fixed some more instances of players not reacting to loose balls
- Fixed corner phase of play not ending when ball cleared way outside area, causing some bizarre knock-ons
- Fixed rare occurrence of play not restarting after a goal
- Fixed player not trying to turn and shoot when close to goal
- Fixed rare instances of unrealistically inaccurate kicks and passes
- Fixed some further issues with players closing down or not closing down properly
- Fixed some headers being unrealistically unchallenged due to collision avoidance code
- Fixed too many unrealistically weak penalty kicks
- Fixed some instances of unrealistically poor first touch
- Fixed players getting stuck in nets when retrieving ball
- Fixed rare issue causing keepers not to pick up routine ball near edge of own area
- Reduced crowding of players going for same ball on some crosses/corners
- Fixed assigned throw in takers not always being used for throws in attacking areas
- Further refinements to closing down and engagement of the ball player
- Some fine tuning of the weighting of short passes
- Made wide midfielders pay a bit more attention to opposition full backs
- One minor ball physics related fix
- Fixed unrealistic dallying on ball
- Less aimless clearances up field when not under pressure
- Couple more tweaks to closing down logic
- Fixed bug where keeper fumbles ball then doesn’t react properly
- Reduced risky passes across defence line
- Fix for ball passing through net occasionally
- Couple more small tweaks to closing down logic
- Further improved wide midfielder tracking of full backs
- Fixed goal kicks not being taken short
- Fixed quick free kicks rarely being taken
- Fixed bug where keeper moves a long distance to retrieve ball at free kick and is caught out of position when it’s taken quickly
- Fixed bug where keepers’ don’t always try to dive at attackers' feet
- Fixed players dropping too deep on some free kicks
- Fixed a couple of bugs causing keepers not to intercept speculative balls properly
- Fixed a couple of bugs causing players not to react to loose balls or passes correctly
- Fixed bug causing player not to attempt jump for ball that he cannot quite reach
- Tweak to off ball movement
- Slightly encouraged high reward lofted passes
- Made players who have just done a burst of running more prone to miscontrol
- Fixed bug where player may over-run ball unnecessarily
- Slight toning down on accuracy of more difficult kicks
- Further fix for incorrect players taking attacking throw-ins
- Team talk fix relating to overfamiliarity with manager talk
- Improved challenging for headers on long kicks
- Fixed nasty knock on relating to players switching off when taking control of ball
- Fixed some lofted passes being a bit extreme
- Reduced power of ball bounce off post and crossbar
- Fixed rare instances of players dallying on ball
- Yet further tweaks to closing down logic
- Fixed some instances of keeper short distribution not working
- Couple more fixes relating to player reactions to ball
- Reduced some instances of dangerous passes in defensive areas
- Fixed rare bug where play freezes when two players close to stationary ball
- Fixed rare bug where quick free kick is decided upon but never taken resulting in deadlock until end of period
- Fixed unrealistic instances of players deciding to take over receiving ball from team mate
- Very slight increase in width of defensive unit to try to open play up slightly
- Fixed bug in pass choice AI that should now result in a bit better decision making
- Slight reduction in 50:50 challenges for lower aggression players
- Small ball collision fix
- Fixed a couple of bugs causing keeper to not try a save
- Fixed a rare bug causing players to double up on closing down an attacking player prematurely
- Made first touch a key attribute for sweeper keeper
- Fixed a bug with players going for the ball too early in the animations
