Anyone know which ROMs have volume rocker skip tracks
PA does
Since 4.2.2 update, I am not always getting notifications, until I wake up the phone.
So now, I just sent an email and the LED is not flashing for a good minute or so. Before it was instant. If I turn the screen on then the email appears instantly.
Is this because the phone is "sleeping" properly now and checking wifi less frequently than 4.2.1 ?
rp2000
rp2000
Should have made it clearer, AOSP design guidelines: http://developer.android.com/design/style/metrics-grids.html
How does PA stick to AOSP guidelines more than CM? I fail to see this.
In wifi settings have you disabled wifi optimisation?
I find when its on i get notifications a min or two late....
Just turned it off now and it has fixed the issue. Thanks!!
rp2000
No Problem.
I think (?) the WiFi optimisation increases the intervals to check for notifications to use less battery.
Yep. I may change it back if it has a very negative impact on the battery. At the moment I get around 2 days, unless it drops below 1 day I am not that bothered.
Curious if 3G has the same type of setting somewhere. 90% of the time my phone is in a wifi area, with screen off, so getting notifications late 90% of the time would be annoying (albeit a minute or two late is not going to be the end of the world!!)
rp2000
is there any way of removing CWM from my phone so i can get the OTA update? want to keep root and get the update but i'm so new that i can't understand anything apart from how to use the toolkit![]()
I'm pretty sure that most (I think all but I don't want to put false information out there unintentionally) of the custom ROMs offer this feature. I run CM myself as it is very polished and stable (find it has very few bugs compared to PA for example), stays close to AOSP guidelines (hence why there is no resizing of navigation buttons, for example), and has the features that I require, nothing more or nothing less. In that respect it is essentially perfect, exactly what I'm looking for. The reason that it is more stable is likely because of its less "experimental" nature.
AOKP has far more features but will generally be a more buggy release. What PA trades in terms of little features it makes up for with all of the layout customisations, though like AOKP, it is generally a more buggy release.
All depends what you are looking for really.
I charge my phone every night, it's a smart phone so I'm used to (and expect) that. It's normally at around 60% plug it in. That's general browsing, ~45mins of voice calls, texting, and having latitude running. Which is all fine. I don't need it to last 4 days by disabling all the features I use!
You don't need too, CWM will install the update.
how exactly?
Is there a way yet to have music playing in the background from any source (YouTube?) and to be doing other things like browsing? Like the iPad is able to do?
I'm interested in the Nexus but Andriods multitasking abilities have been quite shameful in the past.
