I was thinking that too, might get one in favour of my current system and 690.
It was £30 cheaper a few days ago
You haven't seen the officially on sale and in officially in stock one then?
YOUR BASKET
1 x OcUK HD 7990 6144MB GDDR5 PCI-Express Graphics Card £679.99
Total : £691.39
100% with you there bud.
It was £30 cheaper a few days ago![]()
Like i said the other day once you put a custom block on the Titan it will surpass the 690 even of the 690 is watercooled because of the unlocked voltage!
STUFF.
I'd edit this if I was you, even though you haven't linked a competitor you're still driving people to look at competitor sites lol.
@ Tommy, That will be me Tuesday morning at the front door waiting for the delivery van![]()
This is not good:
http://translate.googleusercontent....s.html&usg=ALkJrhhi5pY-c6w8e6ap63Aw6IryW5hrxw
Temperature can affect actual performance!!
Most review benches are open air and in air conditioned offices.
Hence they are cooler than most actual systems.
Now think of your case,especially after a few months of dust build-up?
Also,high end SFF PC systems are being sold with Geforce Titan in them.
What about during summer then??
What he has written is fine.![]()
This is not good:
It appears voltage unlocking is not what we expected and the card is still limited within it's TDP, at most 106%.....
Early indications from some reviews point to the fact the voltage unlocking merely allows you to go up a couple of bins for a very little gain in actual net clock speed.
Air or water or LN2....I still think the upper clocks will be voltage limited by TDP.
Here are 2 examples with Anno 2070 and Battlefield 3 with a rapid test, test temperature stabilized and the same test but with the latter two 120mm fans positioned around the map:
Anno 2070: 75 fps -> 63 fps -> 68 fps
Battlefield 3: 115 fps -> 107 fps -> 114 fps
After reading a few Titan reviews it seems like an awesome card, if I didn't have my current setup I'd definitely go for one.
This is gregster waiting for shops to start listing them.
