Man of Honour
- 14 Aug 2005
- York
Had same thing on mine a wile back, slightly bent mech hanger, replaced the chain and cassette too for good measure.
The mech hanger is the bit that connects the derailleur to the frame, varies in size and shape but just look at the thing you're mech is connected to and see if it's straight. If not get a new one.
Not sure whats meant by badly indexed mech but my guess is they're referring to the upper lower limit screw adjustments / cable tension adjustments to make sure the chain is properly shifting through all the gears.
Rear derailleur adjustments: http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
How to repair mech hanger (personally just replace it):
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.chainreactioncycles.com/Models.aspx?ModelID=21496
Thats the Bottom Bracket that you need Ed, but what size will determine what size you currently have. What bike is it?
If you don't know how to fit it, read up on the net or take it to a bike shop and ask how much they charge.
Had an ace time at Lee Quarry today. It was almost entirely bone dry, dusty in places (!!!) with a few interesting features due to the low temps:
http://img.photobucket.com/albums/v67/Andelusion/IMG_20130224_121605.jpg
Gents, can any one recommend some good cable cutters to get through Jagwire outer sleeve please? (That won't break the bank preferably)
Save yourself a lot of pain and buy some good quality ones, I bought some Park ones a couple of years ago and they've been brilliant, no fraying or crushing.
