I noticed not sure what i am doing wrong here a bit new to forum posting![]()
Same here. This is why it would make perfect sense to put these under water. They could be wasted being left on air.
I don't wanna mess with the cooler, worried it may get damaged.
Gonna leave mine 'stock'.
Hope it can reach 1Ghz on air..
http://imageshack.us/a/img90/8718/img0226re.jpg[IMG]
Here is one pic[/QUOTE]
You should take off the blue plastic from the SLI connection points :)
Ok will do and here is another pic before i installed it. played a bit of hawken last night at 2240 x 1440 with everything maxed out and was averaging 85 fps.[/IMG]![]()
Ok will do and here is another pic before i installed it. played a bit of hawken last night at 2560 x 1440 with everything maxed out and was averaging 85 fps.]
I have left everything as out of box when running heaven 4 benchmark temps reach the 80degrees mark and the card keeps it at that temp. You can hear the fan ramp up its not high pitched more of a woooshing sound. benchmark for the heaven at 2560 x 1440 with tessellation set to medium and aa at 8x is 43.9fps and score of 1105.
The boost clock reaches over 1ghz
If i change my asus titan to gigabyte titan now will i have to pay more then the original price i payed for the asus
