I noticed not sure what i am doing wrong here a bit new to forum posting![]()
Same here. This is why it would make perfect sense to put these under water. They could be wasted being left on air.
.I don't wanna mess with the cooler, worried it may get damaged.
Gonna leave mine 'stock'.
Hope it can reach 1Ghz on air..
http://imageshack.us/a/img90/8718/img0226re.jpg[IMG]
Here is one pic[/QUOTE]
You should take off the blue plastic from the SLI connection points :)
Ok will do and here is another pic before i installed it. played a bit of hawken last night at 2240 x 1440 with everything maxed out and was averaging 85 fps.[/IMG]![]()
Ok will do and here is another pic before i installed it. played a bit of hawken last night at 2560 x 1440 with everything maxed out and was averaging 85 fps.]
I have left everything as out of box when running heaven 4 benchmark temps reach the 80degrees mark and the card keeps it at that temp. You can hear the fan ramp up its not high pitched more of a woooshing sound. benchmark for the heaven at 2560 x 1440 with tessellation set to medium and aa at 8x is 43.9fps and score of 1105.
The boost clock reaches over 1ghz
If i change my asus titan to gigabyte titan now will i have to pay more then the original price i payed for the asus
