**** Official Titan owners thread. ****
If I've not killed my mobo, had a little leak so drying out time :(
That happened to me at xmas so plan B was to get extremely plastered for a few days while the mobo dried out.
On mine the leak went all over the in/out sockets at the back and I though it would never boot up again.
I hope you are equally fortunate and up and running when everything has dried out.
After leaving mine for a few days I gave it a good going over with a hair dryer.
Good luck neil.
quick couple of scores, didn't manage to grab screenshots yet as been messing about trying to get higher clocks but ending up with lower scores lol
stock, Heaven Valley, boost 993mhz, 2679 points
OC 1137 peak boost, but mainly 1084, 2945 points
Nice jump from stock :) Easy to OC?
Good luck neil.
Thanks, it wasn't a great amount of water so here's hoping :)
I think these things will "power Limit" and I'm thinking there will be next to little settings juggling that will make much of a difference.
Mines is running at 93% when it throttles because of heat (even though it's nowhere near the temp target i set for it, over 70C they start to throttle quite quickly... i can see these doing over 1200 on water pretty easy
It's not just heat that's monitored, It's max power draw that will limit the card, "current limited", I don't really know how they estimate % load (I suspect current) also, but it may not make 100% before the brakes go on.
Bottom line is they may not run that much faster when water cooled.
8 Pack seemed to be pretty sure that Kingpin bloke had voltmodded his Titan, obviously with him being the official OCer for nVidia that's different but surely a hacked BIOS or quick solder method will surface soon?
