But at what cost!?
I jest![]()
When I played football (only Sunday league), it was always win at any cost
But at what cost!?
I jest![]()
I'm interested in seeing if the Titan can sustain the overclocks, read a few reports of it downclocking once heat/power limits are breached.
That should complete the green takeover.
Come on Neil.![]()
But at what cost!?
I jest![]()
Peoples obsessions with getting a little number higher than someone else makes me chuckle..![]()
you're in the wrong forum then.
If I've not killed my mobo, had a little leak so drying out time![]()
quick couple of scores, didn't manage to grab screenshots yet as been messing about trying to get higher clocks but ending up with lower scores lol
stock, Heaven Valley, boost 993mhz, 2679 points
OC 1137 peak boost, but mainly 1084, 2945 points
That happened to me at xmas so plan B was to get extremely plastered for a few days while the mobo dried out.
On mine the leak went all over the in/out sockets at the back and I though it would never boot up again.
I hope you are equally fortunate and up and running when everything has dried out.
After leaving mine for a few days I gave it a good going over with a hair dryer.
Good luck neil.
I think these things will "power Limit" and I'm thinking there will be next to little settings juggling that will make much of a difference.
I could resist no longer hopefully they will be here next week![]()
Mines is running at 93% when it throttles because of heat (even though it's nowhere near the temp target i set for it, over 70C they start to throttle quite quickly... i can see these doing over 1200 on water pretty easy
