- 3 Oct 2009
- Wales
Can't seem to find the diet/nutrition thread? certain that there was one?
http://forums.overclockers.co.uk/showthread.php?t=18299646&highlight=diet+macros
Looking at the changes necessary for my diet in about two months when I trim up a bit. The last time I did anything properly it was based around a ketosis style diet & carb cycling. Keeping carbs low with protein & fats high. Is this still advisable or has 'the norm' changed since 3- 4 years ago?
It's all about CBL now brah!
On a more serious note if what you done in the past worked for you then why change it.
I do 6 meals per day but use the -30/-10 approach, so -10 on training days below maintenance and -30 below maintenance on rest day.
I use the IF calculator.
Edit: I used to do IF properly, but in the end i found i preferred 6 meals, so i use IF methods, just not the fasting part.
Thanks, my search skillz are lacking.
CBL this and CBL that! I'll read up on it tonight. I use the IF principles regularly even if on the odd occasion my diet gets a bit dirty for a few days.
That said there's a link to my cutting effort in my DC log, it was tough but worked. I generally stay leaner nowadays thanks to IF and just generally more mass so perhaps you're right and I should stick to what I know.
In short is CBL effectively less frequent carb cycling? but dumping the motherload of carbs in when you do?
Edit: [sillyquestion]I'm guessing that most of the CBL followers haven't bought the book as my googling suggests is advisable'[/sillyquestion]
Thanks, will checkout the IF calculator. I found 2 or 3 large meals is the sweetspot for me.![]()
Just realised I'm eating 350g carbs and 250g protein on training days. Fear dem carbs!
Lightweight. I think I managed close to 450g carbz yesterday...![]()
However, it is a humbling exercise, but even just practising holding yourself in the "upright" position is fantastic for shoulder work.
There are lots of shoulder stability workouts that should be done IMO - it's a fragile and abused joint.
