lol stop going on about this, Matt. They didn't.
The graphs were quite clear what they were saying with regards to max playable settings. I admit I didn't read the comments in depth to see if there was implicit bias but the graphs showed (from memory) marginally higher FPS on nVidia cards at LOWER settings.
The Apples to Apples comparison showed the AMD card being faster.
I dislike HardOCP but I think although I don't like that particular way of displaying information it isn't an automatic reason to suspect bias.
They looked about right to me for Apples to Apples. Unless you use Extreme AA the 680/7970 were even.
I know that my performance numbers were far in excess of what they came up with regardless of which settings they used. High SSAA also uses compute so for a 680 to be any where near a 7970 is bull.
Where's that Sleeping Dogs thread gone?
Tone and I ran High AA and Extreme AA both while overclocked and he removed my underwear at Extreme but I was marginally quicker at High.
Go find it then.
I'm talking about H's results. I know their 7970 ghz performance was not correct compared to what i was seeing on a slower system.
I'd be happy to bench up against a 680 as well.![]()
.We all did it ages ago when it was flavour of the month mate. You've fiddled with your 7970 so much since then you've gone blind and forgot![]()
Because I'm bored - Click for all scores so far.
1920x1080 - Extreme AA, High presets. (Single GPU)
1. LtMatt - HD7970 - 54.2FPS
2. Nickolp1974 - HD7970 - 52.1FPS
3. Tonester0011 - HD7970 - 49.5FPS
4. Rusty0611 - GTX680 - 46.1FPS
1920x1080 - High AA, High presets. (Single GPU)
1. Rusty0611 - GTX680 - 89.7FPS
2. Tonester0011 - HD7970 - 89.5FPS
3. LtMatt - HD7970 - 85.3
I don't think i need to spell it out when you compare them to the extreme results. Something wrong with those HIGH results Rusty.I don't think i need to spell it out when you compare them to the extreme results.
No mentions of clock speeds either.
I think you're confused. They're grouped by Extreme and then High.
Well mine was max OC on my reference card. Tones was whatever his 7970s go to so around 1200-1250 from memory. Some might go higher, some might not. What the point is that they are round about even at the High AA.
I can see that but i know my score is wrong, I'm reinstalling now so should have some accurate results up in comparison to see if they really are as close at HIGH as you say.![]()
). This was all discussed on the thread at the time if you care to read it. That is, nVidia even with AMD at High AA lagging at extreme AA.Well it's just what you posted at the time and it is roughly in line with Tonester's.
Not saying things ain't changed at all - indeed performance has improved for nVidia a bit reading the driver notes (which aren't always true). This was all discussed on the thread at the time if you care to read it. That is, nVidia even with AMD at High AA lagging at extreme AA.
Pretty sure no other 680 got any where near your score either in that thread. So i wouldn't say that would represent the general performance.![]()
If both cards were at stock id expect a victory for the 7970 ghz without doubt at High, even more at Extreme.
Thinking back my card would have only been clocked at 1200 when i ran that HIGH result.
All I did was overclock it. Not like I could add extra volts to it lol.
Interesting theory, but that would implicitly suggest that the 680 gains(ed) more from overclocking to allow it to pull ahead in the benchmark above when clocked up.
Probably, yeah. Mine would have been 1280 ish more like likely, so it isn't a true like for like max OC comparison as 1280 was more towards the top end for 680s whereas 1200-1225 is more towards the low end for 7970s. We're talking small margins though which isn't going to dramatically alter the results.
We'll see. Your results were far above any others ive seen. I'm looking at other 680 single card results on High and yours are 10-15 fps faster than any others i can find. However the ones i have found were not clocked as high as yours.
EDIT
http://i.imgur.com/7qOCOhe.png[IMG]
Stock 7970 almost 10fps faster at 1080p with HIGH SSAA. Ghz edition much much faster.[/QUOTE]
Looks suspect as SLI 680 is suddenly faster than CF 7970 GE. :confused:
Suspect AMD drivers? :p
And anyway, we were clearly discussing overclocked comparisons. Stock comparisons are boring as there's already a plethora of them around.
EDIT
Anand did a review recently. This puts an end to the discussion as its using latest drivers from both sides.
EDIT
Before you come back with they were closer originally. AMD had their drivers optimised for this games month before it was released. Gaming evolved title and they worked so closely with the devs square enix. So the AMD gains would be no more than a few fps at most if that.
Are they overclocked? It's not like you can fiddle the benchmark anyway lol. It's a fixed benchmark which shows you the settings/results in one screenshot.
Here's my result:
I am pretty sure most off the benches ran in the benchmark thread were run before 12.11 drivers which saw big boosts in most games. Rusty's oc results make sense when looking at anand's results. It does seem amd has given more performance through drivers as the anand ghz edition is giving results way ahead of oc benches from september last year. Shows how wrong H were though.
Could be cpu limited in crossfire sli as they are pretty close and scaling ain't great on any of them.
