This guy gets it!
Out of curiosity, could TRX straps do the same kind of thing? Or would the holding mechanism not take the weight?
This guy gets it!
Out of curiosity, could TRX straps do the same kind of thing? Or would the holding mechanism not take the weight?![]()
Speaking of TRX straps, since I'm off deadlifts, I'll try and add these in on my back day after pullups. Or will these interfere with good old dumbbell rows?
I'm sure they'll mostly hit my entire upper back, just looks for some confirmation from the chaps that do them
They will be quasi-closed chain rows, so yes, they should interface nicely with dumbell rows. Pullups, perhaps not quite so much.
Of course it's possible - they;re designed with fat middle-aged men/women in mind.
That doesn't mean it's comfortable, as the 'rings' hang from the same point, meaning they'll be stretched across your back and shoulders.
Hang from the same point? You mean centrally above you? I can theoretically use two sets so I can stagger the hanging point as no bugger uses them?
You gonna get some hate for those squats. Why 20 reps of 65?! You can clearly do more weight at fewer reps which would be far more beneficial.
Well I posted it up for a discussion, so hate is good
I tend to do high volume on legs as they respond well to it. Again part of it is the weight limitation, but I guess I could look to do 100kg for 5 or 10 reps in the meantime?
Depends entirely on what you want to achieve. Remind me if you are wanting size or strength at this current time? That will determine the rep ranges you want to hit.
At 20 reps you're currently hitting endurance territory I think?If that's even a training term
Actually, looking to make some size at the moment. I tend to get the biggest pump from volume in the legs, but more than happy to step up the weight and drop the reps if that is the better option.
Now I think about it, it's what I did with my Deadlift...
