Yeah I've replaced the Asrock A75 board with the new A85 board after reading the horror stories about the other one.
Did you get the mITX one?
Where from??
I suspect forum rules won't allow answer for that. None of the major suppliers seem to be stocking, though.
I suspect that OC should be getting some soon - probably would prefer to clear out their A75 stock first, since pricing appears to be very similar (and, given choice, no-one would opt for the Asrock A75 over the A85x). But, then again, maybe there just aren't many coming in to UK.
That's a shame, it seems the A75 boards basically aren't fit for purpose.
The FM1 Asrock board dont catch fire does it ?
only place that has AsRock FM2A85X-ITX in stock is forest shop, but it is over £90!! bit steep for mITX![]()
Did someone get hold of zotac fm2 itx board?
Found somewhere (just Google 'Zotac FM2 A75') that has stock of the Zotac A75 and A55 (strangely it's not listed on the Zotac site) boards, not sure if it's legit though and i've yet to find any other UK retailer stocking them.
I have both MSI FM2-A75IA-E53 and Asrock A85-ITX and I'm not sure about which one to keep
The MSI seems more stable, but the Asrock is more powerful and configurable.
About the MSI, the only thing I don't like is that you can't set how much RAM is sharing with the GPU, and the non displaying BIOS bug throught HDMI in TV
About the Asrock I don't like the fan control and the incompatibility with backplate's CPU Coolers
What do you think?
What do you think?
 will it go over 1000MHZ with no changes to Voltages??
guys..
MSI all the way!!
ok...
you are not able to assign memory to GPU
you are not able to assign Voltage for GPU - if you want to clock it
you are not able to change Voltage of CPU - if you want to overclock
BUT!!
before booting system, I have clocked GPU to 894MHZ - from default 760MHz
I have clocked CPU to 4GHz without changing Voltage
have changed NB freq to 2000MHZ from 1800MHz again no voltage change
and it is all freaking stable!!!
on Asrock, you had to play with voltages and here on MSI it just works
if I get more time - possibly over weekend, I may use 2400MHz RAM in it to see how much I can push GPUwill it go over 1000MHZ with no changes to Voltages??
have t wait and see![]()
you can assign GPU RAM in the BIOS, its almost "hidden" in the first bunch of settings, i think you have to change from IGP to PEG or something to get the option.
you can undervolt, via software in the OS i use AMD overdrive
