I have spent the past three days testing and playing no end of games on these 3 cards at 2560x1440. After hours of hard work I have a very simple conclusion.
Titan is best, 690 is fastest and 680 does the job.
Simples...
Thats a lot of silverware!
What's the quietest, Moogleys?
The Titan offers the best all round experience it has better minimum frames than the 690 and sees less drops from what I have noticed playing the games.
I took Moogleys findings and placed them into a graph to show the results*
The 7970 and 7950 was my own findings
I swapped out 670 SLI... but for 3 Titan's, but then I did have 3 2560x1440 monitors sat here begging to be gamed on so...
but yes, a single Titan is very close to the performance of 2 670's, but without any risk of SLI problems (though to be fair I'd had none of those either)
if it was single monitor I would be hard pressed to recommend a Titan when a pair of 670's actually perform slightly better for a lot less money, but if you are running say a 2560 monitor and are dead set against SLI then it's the only choice really
Gregster this graph has an error -
Don't forget an oced HD 7950 has the same performance as a 7970.![]()
It wouldn't overclock at all because it had boiled cabbage jammed in it for some reason![]()
All very similar tbh. In a closed case they are all noticeable when being used but none of them are particularly loud just a background whoosh.
Mines got potato in it...
Good work boom. Is it giving improved performance/scores or is it still throttling?
My card doesn't throttle, from what I've read some cards throttle and some don't? I'm sure it's temp related.. Titan's love water lol..
Just hit P14817 on single Titan![]()
Both mine throttle and nothing to do with temps (kept under 50c tonight and still throttled). EVGA and Nvidia are aware of it and if I am honest, I am not fussed. The performance is sweet and these cards fly.
What was your P14817 in?
