Maybe GPU over heating, or SLI bug?
Took a few screenshots of my game at the moment.
What mods are you using? That actually looks amazing.
You could try the solution in the first post here: http://enbseries.enbdev.com/forum/viewtopic.php?f=22&t=1391
Thanks, it runs really nicely too, 40 FPS everywhere when recording with Fraps. Without Fraps I'm sure it would be 60 most the time.
The ENB is Seasons of Skyrim, with SSAO/DOF/Skylighting all turned off. Using Dynavision Static DOF to blur the distance.
Main mods are probably Skyrim HD Lite, WATER, Vurt's Skyrim Flora Overhaul Summer Edition, and Enhanced Lights and FX.
I am going to do a playthrough without mods, then after get them from that great list for a second go later on.
There is a SKSE beta for the 1.9 beta http://skse.silverlock.org/
I'm not using CoT, don't really like it either. Seasons of Skyrim doesn't need it. Project ENB by the same author is the one that works with CoT.
? The shading looks absolutely perfect.Ok guys, I've just got this for my PC. I spent a lot of hours playing it on the Xbox 360 but fancy playing it WASD style since getting my new gaming PC. (i3 3220 - 8GB DDR3 - 7850 2GB DDR3).
I'm not interested in making the game look as realistic as possible, I just want nice visuals whilst maintaining smooth gameplay. I don't want to over do it with tons of graphical addons.
Can anyone please suggest me on the best ones to use? Is there just an easy texture pack I can apply?
Cheers
SSAO is definitely off, and there is no photoshopping.
