constant atioglxx.dll errors and inability to run anything opengl, same here on my windows 7 64 bit
uninstalled them now & now back to 13.1 & now get opencl bug detected when opening GPUZ
Anyone else got first impressions/frametime results on 79 CrossFire setups on the new driver?
Do you need 12.11 CAP 2 if you install 13.3 beta 2 drivers? I thought I read somewhere that caps were embedded with the new beta drivers. If this is true shall I just delete the old CAP file?
Anyone heard of a new driver raising your temps massively? reason i ask mines been jumping from 35C-40C upto 60c, i only noticed because my fans were on overdrive!
i disabled my other monitor but the same! i have gone back to the 13.2 B6 to see if that helps, it maybe something alse as i have had a few errors lately,hope its not hardware.
Also check fan speed settings in afterburner, maybe its running slower than normal.Had to go back to Beta7 of the 13.2 drivers, these ones stopped my voltage control working so i was stuck at full power all the time, tried removing all overclocking programs with no luck, reverted back to beta 7 and it instantly fixed it.
