 - 15 May 2012
 - Louth, lincs
Not sure mate. Ask the creator himself via this thread. http://forums.guru3d.com/showthread.php?t=376094
Ok mate thx
Struggling here...
On stock voltage 1135/1200 got a driver reset. Unigine just crashed straight back to desktop. I reset, increased voltage to 1150, same again, crash back to desktop.
Increased voltage to 1160 this time, the benchmark ran all the way through but a few seconds after giving me the score I got a BSOD. Just increase voltage again?
Keep increasing voltage until it gets stable. Double check that the power limit is sticking at +20%. Ensure temps are staying below 70c.
Keep going. You should be ok up to 1.25v.
Thanks.
1160/1200 - 1190v - Stable.
1185/1200 - 1190v - BSOD straight away.
I increased to 1200v
1185/1200 - BSOD straight away.
Increasing to 1210 now. The limit would be 1225?
Cheers
1185/1200 - 1220v. BSOD at the end of benchmark.
What are my options now?
1200/1200 @ 1.225 - Driver reset halfway through Unigine.
Gahhh... What can I do now then?
Do I start stepping the memory clock up now?
Cheers
Settle for 1175 on the core if you can. Be sure 1175 is stable before you move to the memory.
