Caporegime
- 8 Jan 2004
- Rutland
That borderlands result is likely double what you would see on a single card as mine has never got near that (single 7950 at very similar settings).
Rusty - nice one, proves the earlier point about AA making a big difference.
Bacon - rgr, will list it because dualboxing is standard practice for that game. Almost leet vram usage too
oldestgregg - yeah, seems unlikely - can list it anyway with a question mark if you let me know: your resolution, gpu, quality
@greg,Blackwhite or any other Titan owners, can you do Hitman 8xMSAA full max@1080p-the bit with the helicopter on the rooftops please?![]()
System Ram to Vram - ahh I remember those good ol' days of setting AGP Aperture Size in BIOS ... remember any one ?![]()
Shouldn't there be a telltale sign of VRAM choking which can help you distinguish between overcapacity and caching? Seems like you could identify it in fraps frametime reports or somesuch.
1
I like the initiative but as OcUK has discussed time and time again Max VRAM committal does not equal VRAM required. The whole caching thing just resurfaces again.
Perhaps the numbers might show something usable but I fear it will just be a data set that cannot be used as there is no control.
You do realise that there's a degree of caching involved if excess VRAM is available?
i.e. if you look at Greg's Crysis 3 result it uses 3900MB of VRAM which would suggest that even 7970s can't play it but of course they can.
Or perhaps based on your logic we should all get Titans or 6GB 7970s to max out Crysis 3.![]()
