put emphasis on the compounds (deadlift squat bench and OHP) .
This, i do the above and add Bent Over Row in there and that's my routine three days a week. Best routine i've done ever.
For the HST routine I have been setting up my 15, 10, and 5 RM's for that i need for the work outs.
I will be following A/B alternating routines for the whole of the cycle, just to hit the muscles in a slightly different way over the cycle, but the 15's and 10's will differ to the 5's weeks.
For 15's and 10s the workouts are as follows:
Workout A
Squat
RDL
Incline DB Bench
Pull Downs
Seated Rows
Dips
OHP
Calf Press
BB Curl
Cable Crunch
Workout B
Deadlift
RDL
Bench Press
Goblet Squat
Seated Shoulder Press
Lateral Raises
Calf Raises
CGBP
Cable Crunches
Knee Raises
During 5's weeks the workouts change as follows:
Workout A
Squat
Pull Downs
Dips
OHP
Calf Press
Workout B
Deadlift
Bench Press
RDL
Leg Press
BB Curl
Anyone got a good HST A/B day selection to hand? Decided to give it a go after this week.
Ask Ben Conradi (BennyC) in the FB group, he's a massive HST fan boi.
This is a bit unlikely. Cramp perhaps?Just pulled a hamstring while benching just the bar
Ah well lesson learned
The irony is that I was trying my hardest to improve my form.
I have something somewhere.Anyone got a good HST A/B day selection to hand? Decided to give it a go after this week.
) for the first time in my life ever, I don't care that it was only a 5kg plate, it means a step in the right direction. add to that the fact I am actually 5kg heavier than I was 5 months ago as well.This is a bit unlikely. Cramp perhaps?
Unless your tissue quality is in the 99.9th percentile of terrible, of course.
Remind me, what is your exercise history?
Does it not sound a bit ambiguous "as much as you can 15-60 minutes"?
Just after some input from you guys here. Been looking to mix up my routine now and have done quite a bit of reading in to various other routines. I've mainly been doing HIIT Cardio for the last 4 months and i'm looking to slowly step up into weights but looking for a good platform to build on. In this months M&F I seen Arnolds modern day workout and it looks very appealing to me. it's basically;
1 - 10 x 30/30 HIIT cardio
2 - Bench Press x 15/failure
3 - Lat Pulldown x 15/failure
4 - DB Lateral Raise x 15/failure
5 - Cross body cable row x 15/side
6 - Barbell curl x 15/failure
7 - Swiss ball crunch x 20
Perform as a circuit with no rest between exercises and a 2 minute rest at the end of the circuit. Repeat as many times as you can between 15-60 minutes.
The reason it appeals to me is purely down to it's simplicity and seems to touch all of the bases. Plan is to try it out for 6-8 weeks and see what results it brings.
