I think you guys can rest assured that that you should get a UK (ISO) layout if bought from a UK retailer. Retailer just show the US layout as manufactures tend to use US layout for photoshots.
starmanwarz probably got it imported, I did too with my Quickfire Rapid, as getting a MX Brown in the UK is nearly impossible ATM.
I personally prefer the US layout as it is so much easier to buy key caps and aesthetically it looks nicer IMO cos of symmetry.
for Ryan-3, you might already know this, set windows to US international (instead of standard US), then AltGr+Shift+4 gives you £ sign. I use blank key caps so just set UK layout within windows, iirc altgr+# gives me \ so i don't loose any keys and have a UK layout.
BTW, Kreeeee, you play SF4? seem to remember playing with you on xbox a few years back.
