- 14 Oct 2009
- Rotherham. S.Yorks
should i get a 34c or a futur? i have my eye on both
Used it, wasn't a fan. I just didn't really like the feel or the scent. I use ToBS Shaving Shop aftershave gel/balm which has a mild but nice scent that doesn't last too long. It's nicely moisturising and a 75ml tube lasts for absolutely months!
Med Preps are back in stock at Connaught. Get 'em before I do![]()
nkdman has the gold one in stock. Personally though I think it looks ugly.
well so far my manly shaving is a disaster.
my skin just cant take it, DE89 with a couple of different blades, some decent foam which i got very foamy and some good moisturizer. got a fair few cuts, then a rash and then half of my face flaked away.
Method? warm face with hot water. Apply lathery foam, down stroke, across stroke the first time. Shave was ok, probably about as close as my electric razor
Did this shave a few more times still had plenty of nicks etc.
I then did a gentle upward stroke after the down and across stroke, and boy did it just make a mess. I need to look clean and sharp for work and this was anything but, I then suffered again with a malting face.
Both times i finished with a Alum Block or as i like to call it, the stingy block
not for me?
Cream is Taylors of old street for sensitive skin
Moisturizer is the same
Brush is a Edwin Jagger
Blades used are Asta SP's and SS's.
i expected too much from it but the process is messy and takes ages and it just doesnt fit into an active lifestyle with a busy family, im not used to taking more than 5 mins in the bathroom. if your a single man with plenty of time and having a very close shave is of no issue that it takes almost half an hour then this is all good. i am glad i tried it tho, now ive gotta sell all this pointless gear or give it away lol but it was only about 35 quid altogether
not for me?
Razor choice fail![]()
Sarge78, very nice. Is that a Gillette Popular?
