***The Vapers Lounge***
Status
Not open for further replies.
got an aga t2 whilst I wait for that damn rsst lol and put myself down for a telescopic mech mod.
Also got some Niobium Alloy Resistance Wire and 316 Marine Grade Stainless Steel Mesh, so this will be my first rebuildable.
edit - where can I get some good drip tips?
Have a look on totally wicked, they have a fair few iirc.
Where are you waiting on the Smok RSST to come in from? I only know of one UK vendor who is selling them, and they sold out.
I have this horrible feeling I'm not going to be able to use my ecig in my new office. It's all open plan and the head thinks it would be distracting. Nooooooooo! How will I survive? Vaping in 3 short breaks a day? Bugger that!
E: Now confirmed as no. I'm going to talk to HR about it though and find out why. So unhappy about that :(
I have been using my INNOKIN iTaste (version 3) with the Innokin iClear 16 dual coil clearomizers.
I have not touched a normal ciggie in a week thanks to this device. Gotta say I am really please I bought it.
The amount of vapor it produces is amazing and really satisfies my needs. Plus I like the variable voltage which is cool.
Reason I bought the iTaste was because of this review:
http://www.gizmodo.co.uk/2012/12/the-best-e-cigarette/
In which they rated the iTaste no.1
So far I am really happy! :)
I'm tempted to get Innokin iClear 30 clearomizer as that holds twice as much juice which would be handy.
What seems to be the best tasting e-liquids to get? I would like one which is as close to real tobacco if possible, and I don't mind trying out some fruity flavours as well. I've got a bottle of cherry which is quite nice atm.
The Iclear 30 is very good. It's the best clearomiser type device that I've tried, and I've tried just about all of them. It's certainly a lot better than the IClear16, the only downside of the bigger 30, is you need a VV (variable voltage) battery as the I30 has dual coils, which really struggle on non-VV devices.
Best tobacco I've found is the El toro cigarillos, I never tire of that.
If you're prepared to mix your own eliquids, the Golden rollie flavouring from Flavourart is very good, and more cost effedctive than relying on just the Cigarillos.
I use cigarillos on nights out, and DIY liquids the rest of the time.
Nice one, cheers for the info.
And I have the iTaste vv so I've got variable voltage so no worries there, I'll pick up a iclear 30 along with some El toro cigarillos to try out ;)
I might check out how to mix my own brew at a la
As you have tried both the IClear16 and IClear30 and you say the 30 is better, I was just wondering what makes the 30 better over the 16 (apart from the liquid difference obviously!)
Also have you tried EL TORO VIRGINIA PRIME? As I have been smoking rollies for a while is this more like a GV taste?
The iclear 30 wicks better than the I-16. It should do as it has 16 wicks inside the tank!
Yes I did try Virginia prime and really didn't like it. I sold mine on. But eliquid is very subjective, lots of folk do like it, just wasn't for me.
None of the tobacco liquids taste like a real cigarette though. They're much nicer (when you settle on one you like)
It's normal and good for it to sizzle and pop a bit. It will stop as the coil gunks up a bit though.
I'll swap you some juice for a nova if you don't want it anymore btw. I'd hang onto them though. I had a rubbish experience with mine at first and it lived in my vaping draw for months before coming back to it. You may end up rewicking it or something later on.
I've opened them all, one I took about 4 draws from and now I get a constant burning, But have a 2.8 Ohm brand new head, and then quite a few which have basically been tried then not touched as they weren't wicking for me anyway.
Just thought id say as Im not sure if you think I still have some packaged? Although the only thing which would basically make them brand new once you do your magic is a drip tip!
Also, I go for long toilet breaks and cape every now and again.. been okay with that! Good luck with HR.
Still going strong smoke free, not feeling any better health wise as in more energy levels and so on apart from better breathing.
Yeah that's fine. All I need is the body and heads, I'll rewick them anyway. Bathroom breaks ftw! :p
They must think I have an extremely weak bladder!
Okay, So basically everything apart from the mouthpiece? Dunno how you'd like to sort it as ive not done anything like this, Message via trust or?
Edit: Only really getting on with Menthol liquid on a standard battery anyway, finding flavours such as 8MG Strawberry as a dry hit/taste but by this I don't mean burning I can taste it just the throat hit is strange as you can imagine what I mean compared to the hit from Menthol.
So ordered 3 more bottles of menthol from Liberty Flights and some Duel Coil Carto's, 30ML isn't in stock but the 10's don't work out much more.
cheers, problem I have there are so many etailers to choose from, so finding a decent drip tip and best price takes ages lol
UK:
http://www.ecigwizard.com/tanks-rebuildable/rssgenesisrba.html
Ireland:
http://www.thebestshop.eu/shop/rebuildable-atomizers/235-rsst-rebuildable-atomizer.html
Drip tips (when not used for dripping) don't really mean much. All about looking nice to you and feeling nice on the lips. I like the feel of plastic ones the best but they don't look that great on steal atties. I've got used to metal ones now but I still like the feel of plastic better. You can get some nice looking ones in glass but I never know how well they would suit my setup and they are more costly than anything else.
It is a shame cloud9vaping isn't taking orders since the owner is unwell. They had (have?) a really large stock of drip tips (well everything really)
Yup there the only 2 ive found in the UK area, theres a few german sites but postage is stupid, one of them is apparently getting stock in on the 12th, so keep an eye out this week/weekend - After watching a few reviews ill jump on this aswell, now my original plan was to actually buy an AC9, but missed out on stock at C9V - so this is the perfect plan to get one and see what the fuss is about, and i like the insulated wick hole idea.
It's an AC9 clone at a fraction of the price. PBusardo's review does say that it benefits from drilling the air hole as it's only 1mm, so 1.2-1.5mm is recommended.
The CE8 changes everything
Quite simply, the CE8 is a ground breaking technology in the Ecig market!
We are SO excited to be one of the very first vendors to bring this new clearomiser to you.
No more wick!
No more burnt taste!
The CE8 delivers an ultra clear vape.
The CE8 really is a game changer for 2013 and the ecig industry!
There is no other way to describe the quality of the vape the CE8 produces. You have to try it yourself to believe it.
http://www.ecigwizard.com/accessories/cartomisers/ss-mesh-ce8/ss-mesh-ce5-ce8.html
Going to try one of these on my next order, huge claims being made... I really did like the vape of the Vision V3, but the burning wick, sudden loss of flavour and thirstiness of them are a let down, hopefully these are better
Just ordered the 1.8Ohm version with a replacement head, spent plenty of cash on Vivi Nova's and a CE2 all resulting in a burnt taste after an hour or two, currently on cheapo duel cartos and having great results.
If these are great I have deffo found my feet with choice of liquid and cartos/tanks then the costs will cut and the savings will start although in the near future ill grab myself a VV battery.
Still smoke free, to the vapours!
Just got my vh star kit from vapour hut. 2 questions though, do you remove the rubber cap inside the top of the carto and how long should I let the juice soak into the wicks before vaping? Only used microlites before these so it's abit new to me.
No, you leave the rubber cap inside. Before vaping Id leave it a minute or so whilst giving it the odd spin to allow the wicks to soak up the liquid.
Cool :)
I've left it soaking for half hour and it tastes horrible. Bit like burning plastic. Can't really taste the juice.
The Vivi heads tend to have a slight plastic taste until you have gone through a tank of juice or so, although Ive just got rid of using a tank as I have had problem after problem with wicking which seems like what problem you may be having.
Simple 5 for £8 Duel Coils doing me just fine, hoping the CE8 I ordered is the next best thing, Wickless tank duel coil carto system. S shouldn't have problems with the juice wicking.
Status
