Good strongman deadlift.
I'm assuming you weren't in that video?![]()
Can I ask, what have you tried on your legs?
Squats? Lunges? Split squats? Hack squat? Leg press?
Bulgarian split squats, start them at BW and see how they feel. Hell, you can try them right now with your sofa/chair/bed.
How much weight is on the leg press when you do it? What's your BW now?
It's possible that you just have some jacked up tissue quality/tightness either around your elbow or shoulder.Random ache pain in my lower bicep every 20 mins or so,I haven't been training.
and taken a week and a bit off from the gym =/
Should i go see a Dr?
Delvis, I seriously doubt that BSS are are good idea for a guy like opeth...
107.5 on a leg press...
QUOTE]
Probably not, but doing leg press all the time won't be doing muchIf he can leg press, you would presume some form of squatting pattern would work as well?
Anyway, it was more 'try them, if they hurt, don't do them'
Would anyone check my form on squats? Doing 60kg in those videos but I would normally squat 75kg.
I think I'm doing high bar squats but I'm trying to do low bar squats. How far should the bar be down? Feels very uncomfortable holding it further down.
Post videos (privately to me if you want) of you doing those exercises you listed (leave out the extensions and curls), saying whether they hurt as you were doing them, and I'll give you my opinion of whether you can be fixed or not.
Your physio getting you to do lunges sounds a bit lolsy.
