That's how I see it, I have no plans to change out for a 55 as i'd lose options which I really notice, and I would gain loads more power. The power is wasted though as I drive like an old man
I am thinking about a quad pipe conversion though, as I do definitely prefer the AMG setup aesthetically.
Repair bills, mine has not gone wrong at all. It did for the first owner though, who suffered ABC failure shortly before I bought it and had the struts replaced at a cost of £8000 (why people pay these kind of bills I am not sure), and then the pump fail with another bill for £2000.
Roof seals are also something which leak letting water into the boot, which then collects at the bottom, where the PSE (central locking air pump) and the roof hydraulic pump conveniently happen to sit - ruining them. I will never suffer from that though as I never leave my car in the rain, and neither did the previous owner. Therefore my car has never really got wet unless it was being driven without thought for the weather, or caught elsewhere off guard over night or something.
In reality all of the bills are massively over egged. As is the case with all cars IME, no cars need cost much to run and mine doesn't scare me at all due to this. A couple of examples include;
ABC strut new price £2000 fitted (hence my cars £8000 main agent bill) - Rebuild cost 150 quid + labour to remove and refit (not too bad at all, its only a strut).
ABC Pump + pressure block thing new price £2000 fitted - Used costs for these sub £500. Also mention of rebuild options for even less on forums (not looked into this much).
PSE pump fail replacement £1000 fitted - Rebuild cost 50 quid with another cheap C-Class pump as a donor for impellor parts etc.
Gearbox failure (unlikely, probably the worst failure you could get) - New price £game over, thousands. - Place recommended in London for example, £1200 rebuilt better than OEM.
The list goes on really, you don't need to replace much on these cars. The prices of parts have caused a rebuild market to emerge.
Tyres - I drive like a granddad and take loads of mechanical care of the car in terms of driving style so all my stuff lasts ages. Tyres front 30k, rear 20k. Pads 30k+ etc....
