see the dailies argument is a bit annoying to me, they are only annoying if you choose to do them ALL every day. Getting VP capped isnt an issue now and the newer factions are easy to gain rep with when doing the dailies.
The biggest problem they had imo was at the beginning when so much content was gated behind Golden Lotus rep. You had to get it progressed before you could even begin to start on shado pan or August celestials, which made getting those gear items or profession recipies a double gated affair.
Now the one point i do concede is that this expansion has been very hard on people who like to maintain a number of toons, my druid main ive had no issues with, running LFR i can fill gearing gaps i dont get from normals or VP gear.
But trying to do that on my hunter and warrior also just drives me insane. So my normal routine is to get VP capped on my druid asap each week then chill out on alts just doing the daily heroic and whatever LFR's i need. With the valor buff it makes capping those toons easy. The problem for me is gaining the relevant rep on those alts. Even with the championing of factions and the tillers quests im still not exalted with the starting factions let along people like Shieldwall/Dominance.
I dont think ive seen so many people get burned out in an expansion so quickly, but its obvious that those same people simply MUST have every rep maxed, must have every upgrade etc.
For someone just enjoying the game at their own pace im still enjoying MOP, easily rate it my best expansion so far
