- 2 Jan 2012
- UK.
The Latest:
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
NVSlimmer
https://www.guru3d.com/files-details/nvidia-driver-slimming-utility.html
Download the NVIDIA driver slimming utility, it is exactly as it says so you can trim down your NVIDIA driver install base.
As described by the programmer uKER , having trimmed NVIDIA drivers for as long as he can remember, the man decided to make a utility to help make the modification and installation process more bearable. Now, this idea has transformed into an easy to use utility usable for the general public. With the tool, you can select the many modules that form the driver, and select what you need and/or want to be installed. Once you hit apply, it deletes the modules the user didn't choose, and offers the option to install the driver. The app is in early staged and will likely see some updates and improvements. Hope you find it useful. Any bug reports and/or suggestions are welcome, you can check out the dedicated forum thread where the author is active.
Nvidia GeForce Experience:
